Russ
Surface Pro 3, Win10 Pro, 1703/15063,
Marvell Avastar Driver 15.68.9112.23 (also tried two previous versions + Generic)
Virus scan negative
Three different mice -- all of which work on other devices
Problem was present before OS upgrade. It was present before she took it to China, but I wasn't able to find a solution then either. Don't know when it arose, so have no idea what might have been the precipitating event.
Stuff I tried, in various orders & combinations:
* Turning Bluetooth On/Off
* Removing/Reinserting mouse batteries
* Uninstalling/Reinstalling Marvell Bluetooth Radio Adapter
* Reboot & Cold start
* WiFi: Off, 2.4 & 5
* sfc /scannow -- Negative
* Prayer
Add Bluetooth device brings up the appropriate box, but does not find the mouse after continuous searching
It does find an "Unknown Device" which I have not yet identified.
It can find my Windows phone (ATIV Odyssey), but it was previously Off and across the house, so no cross-talk problem.
I have read every "Bluetooth" thread in this section, but no help.
Any suggestions that do not involve Refresh/Reset will be appreciated. This is Ladyfriend's machine, and a Reset would be way too complicated due to language issues and other stuff.
Thanks,
Russ
Virus scan negative
* Prayer
Thanks,
Russ
