PavtubeVideo
Although Asus VivoTab Smart promise to support DivX or Xvid videos playback, users still have many issues when they enjoy AVI videos on Smart tablet. Mainly about the video playback quality. A bit choppy, audio and video are not synchronized, without audio and more. In fact, not only windows 8 tablet can’t handle AVI movies alright. Many android devices also have errors to play them. Perhaps AVI inherently complex. How to make AVI videos compatibled with Asus VivoTab Smart?
This problem can be easily solved via a Windows 8 Video converter. The one produced by Pavtube Studio is taken to show you how to convert AVI videos for Asus VivoTab Smart. Follow the guide to make it.
Preparation in advance:
Download and install the VivoTab Smart video converter ( Mac Version ) on your PC. The installation is very simple. Just according to the prompt step by step. It is worth mentioning that, during the installation, a streaming server app also installed by default. Which can help you streaming any audio and video files from your PC to Android, Windows 8 and iOS devices, allows you to play local videos on these devices over wireless network.
Quick Guide:
Step 1. Launch the AVI to VivoTab Smart converter. Import your AVI files into this program. You can import Multiple files at one time.
Step 2. If you wish, you can make some simple editing on your videos. Like add 3D effect, crop, trim, add watermark, adjust volume and more. Or directly skip this step.
Step 3. Choose video format as output for VivoTab Smart. I suggest you selecting “H.264 Video (*.mp4)” in “Common Video” category.
Step 4. Click “Settings” to custom the video quality. In order to fit the display of Smart tablet. You’d better adjust the video size as “1280*720″, bitrate 2000-3000. You should know, the higher bitrate, better video quality and the bigger file size.
Detailed information:
Video
Codec: h.264
Bitrate: 2000~3000
Frame rate: 24
Audio
Codec: aac
Sample rate: 48000
Bitrate: 128000
Channels: Stereo
Step 5. Start transcoding avi to mp4 for Asus VivoTab Smart.
Tips: If you want to combine multiple videos into one, just check the “Merge into one file” button before start converting
Actually, this AVI converter can not only deal with AVI videos, most movie files can be handled well. The video formats including Tivo, m2ts, mov, vob, mkv, wmv, flv, swf, mkv, AVCHD, mxf, tod etc.
When you get the converted video file, you can use the USB cable to transfer them to the tablet, or use Streaming Server ( Learn how to here ) function to make it. After that, you can play AVI videos on VivoTab Smart anytime, anywhere.
Source
Quick Guide:
Video
Codec: h.264
Bitrate: 2000~3000
Frame rate: 24
Audio
Codec: aac
Sample rate: 48000
Bitrate: 128000
Channels: Stereo
Source
