A few strange problems. . .Volume button re mapping itself. . . thoughts
inthesahel
I am wondering if anyone can help with some weird problems about two weeks ago, I went to sign in and Hello wouldn't work, I turned it off and back on. Restart and nothing changed. I checked drivers, checked for updates. Applied all updates, uninstalled driver and reinstalled. Nothing worked. I just left it and would try to fix it later.
I also noticed that the camera app, officelens and other camera apps didn't work.
While doing this I did an update to KB4022715 and before that KB4023834
That didn't help, but yesterday I started noticing another strange problem, I was listening to some
music and went to turn it down and it took a screenshot, I tried to turn it up and the task manager showed
up as if I hit ctrl+alt+del
Any suggestions on what I might try?
Thanks
Don't know if all those problems are related, but the screenshot issue sounds like a problem with the buttons. To take a screenshot on SP4 you hold the power button down and then press the volume-down button. So, could some dirt or lint be wedged into your power button partially holding it down (or keeping it from fully popping up after it was pressed)?
